Engine breaking up sputters help?!!!
I gotta 95 civic with a b16a2 and when I hit the gas it pulls but it sputters and sound like it breaking up. I just put new plugs and wires in it today and it's still doing it. Please help!
Re: Engine breaking up sputters help?!!!
any codes?
Describe "breaking up" - is this misfiring?
Make sure that all the plug wires are on all the way on both ends. If not it can misfire.
But idk because it doesn't do it all the time. When I give it gas it's like it's popping out the exhaust close to a backfire
set your distributor to full advance see what that does....
loosen the 3 12 mm bolts on the distributor and push the distributor toward the firewall as far as you can go.
and come back and tell me what happens
also,i could be wrong here. but it could be a fuel system fluke right? fuel pump not pushing fast enough, injector fowling out, bad fuel filter.
