97 del sol si/d16y8. check engine light.
So I installed a new radio and drove my car the next day to work... after connecting my battery back on. Everything was fine. The car sat for 2 days, then I started it up and an engine light comes on. I never had an engine light come on before. car starts up fine, drives fine, no idling issues. Nada. Did I do something? I never had this happen to me before o: cat has been changed to brand new one in january as well as o2 sensor.
Re: 97 del sol si/d16y8. check engine light.
If you don't have an OBD2 Code Reader, this trick will need only a paperclip/jumper wire:
http://www.fitfreak.net/forums/fit-d...ode-check.html
https://honda-tech.com/forums/acura-tl-rl-zdx-17/2004-tl-how-do-i-reset-my-%22check-engine%22-light-2025781/
http://www.ehow.com/how_2214653_read-obd2-codes.html
So I made a video, can anyone decipher this? My coworker said I might need to clean my IACV. So I told him okay, I will, but I don't want to end up doing it, then clearing the code and have it not be the exact problem, although I noticed once I started car, the idle shot up, then went back to normal.
www.youtube.com/watch?v=T5QjZhnmF5I&feature=youtube_gdata_player
72, 74. Random misfires in cylinders 2 and 4.
When was the last time you replaced your plugs, wires, cap, and rotor? Reset the ECU and start the car again - does either code come back?
I can reset the ecu and see what happens tomorrow. Thanks.
Since they're random misfire codes, they'll stay stored even if the problem never was really a problem. Sometimes it happens. The reset should be all you need to clear the codes - if the car is driving normally, they shouldn't come back.
jena_blondie
18
10-07-2017 07:43 PM
Guitarzann
12-13-2005 10:21 AM
Solracer
02-18-2003 06:45 PM
