95 civic fuel gauge problems?
95 civic dx with b20b problem is my guage reads half tank or just under half but my car won't start for nothing fuel pump primes like its supposed to and everything works fine until it gets under half tank ne ideas y this would be could my gauge on dash be bad and reading wrong fuel pump primes the whole time ..??
Re: 95 civic fuel gauge problems?
Your fuel pump priming doesn't mean there's gas going through the line, it's possible your gauge in the dash could be bad, or the sender in the tank could either be the wrong one or could be having an issue. I've had success before checking the back of the cluster for corrosion, the metal lines running across the back of the cluster sometimes can "bleed" into each other, causing weird signals and readouts, or just flat out not work. Quick, simple thing to check, then i'd make sure your sender is getting a good connection before trying anything heftier or more expensive.
Turns out my cluster gauge for the fuel was off by half tank took runnin out of gas to figure it out lol but thanx for the help
pyang004
06-04-2012 07:57 PM
JDM_Spec_SI-R
09-20-2006 05:53 PM
