How to tell TDC on b16a2?
I think I jumped a tooth while trying to adjust the tension, I want to mark sure it's all set before starting the car. I can get pics if needed.
My problem is my crank pulley does not have any white paint on it and the cam sprockets only have the UP mark (no inner markings to tell when they are positioned correctly to each other). Instead of white, the crank has 3 hash marks about 1.5mm apart from each other and a 4th has mark about 15mm from the 3.
Also, I fortunately marked the belt and sprockets just in case but they were not lined up at the time of the belt slip, how many cycles will it take until they line up again?
Re: How to tell TDC on b16a2?
Is it TDC every time #1 is at its highest point? I thought it took a few cycles to be at true TDC. At least that's the way I have to get our Subies TDC.
TheCrimsonGhost666
08-21-2010 09:49 PM
JohnnyEF
21
06-08-2003 04:41 PM
