unknown problem frustrating
so here is the whole story i have a odb1 b16a in a 99 si.i accidently popped the clutch with the car in first from a stand still, before the the car worked perfectly but now it wont start. i changed the iacv, fuel filter, plugs, wires, dizzy cap and rotor, valve cover gasket. i cleaned the fitv. the car will turn over but will not start, i am not throwing any codes. im getting really frustrated i am out of money and and this is my only ride to work. can someone please help me and try to point me in the right direction.
Re: unknown problem frustrating
im going to buy a new main relay since i just put in a new fuel filter how do i prime or bleed the fuel lines if i have to
I wouldn't throw parts at it to fix it some diagnostics would help
that's a flow chart to help you eliminate things it could be
http://www.ifitjams.com/starting.htm
Are you missing spark, fuel or compression. Always start here rather than throwing money at something that is not the problem. If your fuel pump gave the ghost then putting on cap, rotor and wires does you no good.
Direction:
Spark
Fuel
Compression
Direction:
Spark
Fuel
Compression
so i check my wiring and changed the main relay and now i got this http://www.youtube.com/watch?v=lcEdB...ature=youtu.be im wondering if i should buy a new FITV
