clutch free play
clutch free play
just put in new master and slave cylinder. pumped and bleed it 20 times,with full clutch fluid. no signs of leaking anywhere ,but it still have free play half way down . please help
Re: clutch free play
open the cap and then open the bleeder valve untill it has a steady stream comeing out of the valve and then have somebody pump on it a bunch of times and then tell them to hold it to the floor crack the valve back open and let the air out till u get a solid jet of fluid and repeat till you do just like bleeding breaks oh and dont let them let up the peddle till u close the valve back other wise ur just suckin air right back into it
You adjust the rod/pedal play? 14mm bolt for the master cylinder rod where it meets the pedal.
http://autorepair.about.com/od/fixit...dal-height.htm
around 8:30
around 8:30
