to all eg with d16z6 & tranny guys
with stock motor and ex/si d16z6 tranny what RPM are you at during 70mph?
i was driving a eg ex and when i was going 70mph it was only like at 2700rpms
did u get a dx/lx/vx/cx tranny?
Re: to all eg with d16z6 & tranny guys (Charlie Moua)
Check out http://home.cinci.rr.com/mistab0ne/tranny.html
You should be at 2650 at 60mph and 3533 at 80mph with an EX tranny.
However, with the inaccuracy of stock tachs, I think still could be an EX tranny.
Modified by 96coupe at 10:42 AM 11/24/2003
Re: (twistd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twistd »</TD></TR><TR><TD CLASS="quote">well i also think it depends what gear he's in.</TD></TR></TABLE>
5th gear.
5th gear.
Re: to all eg with d16z6 & tranny guys (5thgencivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5thgencivic »</TD></TR><TR><TD CLASS="quote">Right around the fill plug on the tranny. I think it's a little above it but I can't remember.</TD></TR></TABLE>
anyone else confirm?
can i see it from the engine bay or do i have to get under the car?
Moderator
Re: to all eg with d16z6 & tranny guys (96coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96coupe »</TD></TR><TR><TD CLASS="quote">.
Modified by 96coupe at 10:42 AM 11/24/2003</TD></TR></TABLE>
the tach is mostlikely way off....usually 10-15% if not more!
D Tranny Guru
tach and/or speedo is off.
DX tranny, 3000 rpm = 72 mph on the speedo MY car.........
real speed = 71.15 mph
2700 rpm in CX/VX tranny would be 80 mph.
http://nonsense.netfirms.com/speed.html
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Charlie Moua »</TD></TR><TR><TD CLASS="quote">
can i see it from the engine bay or do i have to get under the car?</TD></TR></TABLE>
A small mirror would make it easy to see.
Re: (twistd)
It also depends on the tire size.
D Tranny Guru
Re: (Chiovnidca)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca »</TD></TR><TR><TD CLASS="quote">
It also depends on the tire size.</TD></TR></TABLE>
wrong there..........
The tranny/VSS/speedo will never know what size tire is on the car.
Re: (Mista Bone)
is there a test you can do to test if the tack/speedo is getting correct about of amperage/volts?
Also where can i find that tranny code?
I though that the smaller tires you have the faster you accelerate but with less top speed due to the diameter of the rims/tires.
The car has 14 optional allow with some 195/55/14 on if that mattered.
Re: (Mista Bone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone »</TD></TR><TR><TD CLASS="quote">
The tranny/VSS/speedo will never know what size tire is on the car.</TD></TR></TABLE>
Yep your right, it will affect the actual speed of the car though.
Just crawl up under the car and check. You should'nt have gotten into this whole car scene if you did'nt want to get a little dirty every now and then.
Re: (Mista Bone)
The tranny/VSS/speedo will never know what size tire is on the car.</TD></TR></TABLE>haha i dont dare ques mistabone but isnt it true that if the tire size is wrongit will throw off the speedo by a few mph???
Re: to all eg with d16z6 & tranny guys (Ricey McRicerton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton »</TD></TR><TR><TD CLASS="quote">
Just crawl up under the car and check. You should'nt have gotten into this whole car scene if you did'nt want to get a little dirty every now and then. </TD></TR></TABLE>
yeah, easy as pie ... just check it out, good to know
Re: (ekb18cCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekb18cCivic »</TD></TR><TR><TD CLASS="quote">haha i dont dare ques mistabone but isnt it true that if the tire size is wrongit will throw off the speedo by a few mph???</TD></TR></TABLE>
This is only true if you were to measure the speed with an external meter, like RADAR. It will not affect the speedo in relation to the tach.
IMOTEPHT94501
07-09-2004 11:21 AM
