D16Z6 questions
cthulward
D16Z6 questions
alright, so in the coming days i will be taking delivery of a '93 SI. the car is nearly pristine (as in *almost* stock) with just over 90,000 miles on it.
the problem is, it burns oil under full-throttle acceleration, seems like ring wear. my question is, should i buy a used engine or to just rebuild the one ive got? i have experience building engines, so my skills are not the question. im just wondering about prices and the quality of used engine that are available (keeping a d-series). i did a search on d16 rebuilds, and the threads that came up werent terribly helpful. perhaps im using the wrong search terms.
so what do you EG people think? go the easy way and buy a used motor, or spend the time (and money) on a rebuild? or should i get a used motor and freshen it u while the current one kills itself?
thanks in advance for helping a clueless n00b
since i am awaiting for my permit i am getting tips from you guys...if dont know anything but i would say rebuild...oil is a terrible smell when it burns LIKE WHOA...now lets go enjoy a bowl of pho...
Moderator
Re: D16Z6 questions (hondan00b)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondan00b »</TD></TR><TR><TD CLASS="quote">alright, so in the coming days i will be taking delivery of a '93 SI. the car is nearly pristine (as in *almost* stock) with just over 90,000 miles on it.
thanks in advance for helping a clueless n00b </TD></TR></TABLE>
drive it as it is....put oil in it when needed.....do a compression check....i wouldn't rip it apart until absolutely neccessary....like i'm burning 3 quarts of oil a week!
In The Garage
it may be valvestem seals. when vtec engages, the valvestems move more, causing more oil to make it past the seals. most vtec hondas that start butring more oil when vtec engages need new valvestem seals. it's a cheap fix (a set of 16's ~$30 from honda), and no biggie if it doesn't work good luck
-Shawn
-Shawn
Korey Klausing
11-19-2016 06:36 AM
