d16z6 into 94 civic dx... starter wont crank.
everything lights up. battery works. the d16z6 came out of my car working and now has b18c. we put the d16z6 into my friens 94 dx and it wont start. doesnt crank. could it be a bad starter after sitting for awhile?
Re: d16z6 into 94 civic dx... starter wont crank. (wizzards581)
TRUE! starters are very fragile (in my experience)... through my swap, i ruined my sohc starter... remove it and test it out!
Moderator
make sure tranny ground is on....
make sure 12 volts is bolted onto starter!!
most importantly make sure there is a good connection with the ground clip that goes on starter....i'll bet that it is not on.....
if that doesn't work ..... tap starter while a friend turns car over....
if starter is bad it should click and make a sound....
Re: d16z6 into 94 civic dx... starter wont crank. (chad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad »</TD></TR><TR><TD CLASS="quote">make sure tranny ground is on....
if starter is bad it should click and make a sound....</TD></TR></TABLE>
thas my first thought.. im pretty sure it's that too..
Re: d16z6 into 94 civic dx... starter wont crank. (Kikomon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kikomon »</TD></TR><TR><TD CLASS="quote"> got a d series starter if you need it</TD></TR></TABLE>
mustninty20
09-27-2007 01:29 PM
92EG8
14
08-25-2007 12:11 AM
onestrongcam
11
08-13-2007 01:46 PM
