What offset on rims??
on some 16X7 rims what offsets can you get by with on an EK without it looking to far in or sticking to far out?? TIA
adaM
adaM
Solbros Owns Me
Re: (STEALTHMODECOUPE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STEALTHMODECOUPE »</TD></TR><TR><TD CLASS="quote">what about 34?? if not whats wrong with 34</TD></TR></TABLE>
I'm probably going to run a 28-32 offset with 14x6 inch wheels...which is RIGHT at the fender.
With a 7 inch wide and a 34, you might start to stick out
Re: (Emerika)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Emerika »</TD></TR><TR><TD CLASS="quote">
With a 7 inch wide and a 34, you might start to stick out</TD></TR></TABLE>
DOH! thanks for the info though
adaM
adaM
I forgot more about hondas then you will ever know....
Location: hop,skip, and a jump from the city,, new friggin york, USA
1 Post
Re: What offset on rims?? (STEALTHMODECOUPE)
7" +38 is just about the limit you can go. also, depends on what tires you run. i use 225 width hoosiers, which are a lot wider than any street tire.
i run a 8.5" wheel with +19mm offset, but some people have referred to me as "crazy". go figure.
be professional
Re: What offset on rims?? (rodney)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rodney »</TD></TR><TR><TD CLASS="quote">7" +38 is just about the limit you can go. also, depends on what tires you run. i use 225 width hoosiers, which are a lot wider than any street tire.
i run a 8.5" wheel with +19mm offset, but some people have referred to me as "crazy". go figure. </TD></TR></TABLE>
13x8.5s with 225 HooHoos - best wheel/tire combo ever
