SRR rear tie bar with ITR sway???
Do you know if this combination will work on 92-95 eg hb?? Just want to know if this will work or not. thanks
Re: SRR rear tie bar with ITR sway??? (SkyeC)
I am getting an ITR rear sway with BSQ kit. I looked at where my rear tie bar is located and there is no place to install the BSQ kit to the subframe.
does that mean i don't need the bsq kit (reinforcement kit) to install the itr sway bar if I already have the srr reat tie bar
Re: SRR rear tie bar with ITR sway??? (eEKEGg)
i've had my srr rear away with just a gsr rear sway...gave the car hell in the twisties and bumps but no sign of rippage or bending.... looks god too!
Re: SRR rear tie bar with ITR sway??? (eg6beater)
Yeah, it provides good support over a pretty large area. Check out http://perpetualconcepts.com for more info.
i'm getting itr sway bar and it's thicker 22mm. I think GSR sway is 19mm. Don't you think reinforcement kit is still necessary?
GSR rear sway is only 14mm by the way. And yes a reinforcement kit is definitely suggested for the ITR rear sway. So basically you are just asking if you can use the SRR piece as the reinforcement? It would be like running something similar to the Comptech set-up. If you mounted the rear sway to the SRR piece then there wouldn't be a need for Beaks/BSQ since those mount to the actual subframe.
IntEGNYC
01-10-2003 10:38 AM
chethewitt
11-05-2002 12:16 AM
