squeak squeak go away???
If i sit in my car and not have it on or any music and just push the clutch in and out repeatedly, it makes this horrible squeak. And when i start off in first gear from a start it sounds even worse. Anyone have any explanations or hints on how to get this to go away. I appreciate it. Thanks.
Re: squeak squeak go away??? (cegleitz)
I had the same thing. Kinda sounded like an old wooden door opening, right? And you can feel it in the clutch too, kinda like a rusted spring. My buddy thought it might have been the throwout bearing.
Re: (EVIL_EKology)
Mine does the same thing wen it's cold. I remember there is somewhere in the pedal you can grease to get it less squeaky, but I don't care to fix it.
Re: (Ricey McRicerton)
you can put grease in the slave cylinder to make the squeek go away, but if its coming from the pedal also just get down there and find the spring behind it and give it some grease and make sure everythings ok down there.
Re: (Echo7847)
yeah mine does the exact same thing, but only when it's cold. i thought it was the throwout bearing, but i replaced it with a new one (along with clutch), and it still does it. it's probably something in the pedal assembly. i'm not too worried about it right now.
sniper_king
08-02-2013 10:37 PM
illusion
03-08-2003 07:06 AM
