Help with Removing Lower Transmission Brace/Changin Oil Pan on 96 LX
It looks like I need to remove the transmission brace which is covering some of the oil pan nuts along with the A pipe from the exhaust to change the oil pan on my car.
Do I need to support the transmission with a jackstand or something when I do this? Is that brace easy to remove/reattach?
Also, can I get away with just removing the A pipe where it attaches to the header/catalytic convertor and letting it hang. Will that give me enough clearence to drop the pan and put the new one in?
Otherwise I will have to tackle some very deteriorated spring loaded bolts that hold the A/B pipe together.
Thanks
Thanks
Re: Help with Removing Lower Transmission Brace/Changin Oil Pan on 96 LX (justint)
I just changed my oil pan today on my 97 dx.
That brace you're talking about connects the tranny and block I believe. You dont need to support the tranny. There are 4 bolts, two on the tranny (14mm I believe) and two on the block (12mm I believe). Its easy to remove/reattach
Yes you can get away with just removing the A pipe which is what I did but it was annoying.
HTH
HTH
civicSF98
07-20-2009 09:24 AM
silverskateEF9
03-06-2008 06:48 PM
