honk button doesnt work
Old Jan 8, 2004 | 03:57 PM
RedHackBatch's Avatar
Default honk button doesnt work
my honk button doesnt work. is there a fuse or something that might be out??? or any one know what might be the problem??
Old Jan 8, 2004 | 03:58 PM
Jimmy's Avatar
Global Moderator
could be numerous things...
check your fuses and wiring..could be a short
goodluck
Old Jan 8, 2004 | 04:10 PM
Default Re: (USDMDC2)
thanks...if it is the fuse, which fuse would it be??
Old Jan 8, 2004 | 04:11 PM
Ausmith's Avatar
Default Re: honk button doesnt work (RedHackBatch)
Honk button?
Old Jan 8, 2004 | 04:12 PM
flyingduck04's Avatar
Does the button click when you hit the button? If it does then it could be a short between the horn and the actual horn.
Default Re: honk button doesnt work (Ausmith)
haha i dont know...is there a correct term for it??
Old Jan 8, 2004 | 04:14 PM
Default Re: honk button doesnt work (flyingduck04)
ah yes! horn! haha any way yes it does click...how would i check for this shortage??
Old Jan 8, 2004 | 05:22 PM
I honestly dont know but my 95 civic has the same problem and i asked a mechanic at a local shop and he said that it is short somewhere in the horn itsself.
Sorry i cant be of more help
Old Jan 8, 2004 | 06:02 PM
ndogg's Avatar
next step is to test your horn by hooking it up to 12V.
Old Jan 8, 2004 | 09:26 PM
ItecRevolution's Avatar
Try jumping your horn with jumper wires directly to your 12volt batt. If your horn works than its either, a fuse, rely, wires/connection, or a switch.
Old Jan 8, 2004 | 10:23 PM
TurboBumblBee's Avatar
Default Re: honk button doesnt work (ItecRevolution)
my cable reel is bad and my horn, cruise control and airbag do not work! it probably the most expensive part to replace w/ diagnosing somehing like this but owell ill just have to get the part
Old Jan 8, 2004 | 10:39 PM
meccA's eg6's Avatar
Default Re: honk button doesnt work (Hybrid95CivicEX)
mine stopped working after i put the alarm in and took the aftermarket cruise control out?
Old Jan 9, 2004 | 04:44 AM
Buzzbomb's Avatar
honk button, that made me laugh.
When I first bought my CRX, the horn didn't work. The problem ended up being in the steering wheel itself. A little metal tab that gets pushed onto a metal ring to complete the circuit and activate the horn was bent out of wack. I just had to re-bend it. It's something to check.
Old Jan 9, 2004 | 05:04 AM
Grimm's Avatar
Default Re: honk button doesnt work (Buzzbomb)
Is your SRS light on? If it is it could be your cable reel in your steering column, (Well it could be that regardless) anyway... The manual should tell you where the fuse is.
Mine dosen't work either
Old Jan 9, 2004 | 06:21 AM
EG6VTi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Buzzbomb &raquo;</TD></TR><TR><TD CLASS="quote">honk button, that made me laugh.
When I first bought my CRX, the horn didn't work. The problem ended up being in the steering wheel itself. A little metal tab that gets pushed onto a metal ring to complete the circuit and activate the horn was bent out of wack. I just had to re-bend it. It's something to check.</TD></TR></TABLE>
yeah that happened to mine when i got an aftermarket steering wheel, worth checkin
honk honk
Old Jan 9, 2004 | 01:51 PM
ndogg's Avatar
Default Re: honk button doesnt work (Grimm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Grimm &raquo;</TD></TR><TR><TD CLASS="quote">Is your SRS light on? If it is it could be your cable reel in your steering column, (Well it could be that regardless) anyway... The manual should tell you where the fuse is.
Mine dosen't work either </TD></TR></TABLE>
it cant be the cable reel because he said he hears the relay clicking when he pushes the horn.
Old Jan 9, 2004 | 01:53 PM
Witty's Avatar
My Cable reel is out too. Looks like this is a really common problem.
Old Jan 9, 2004 | 01:55 PM
Ej1_coupe's Avatar
Default Re: honk button doesnt work (ndogg)
well atleast you didnt have my problem, my horn stuck, and guess what woke me up at 3:00 in the morning, my horn cause somehow it was stuck again, then in the middle of school for about 45 min my horn was going off, then i went and got it fixed.. good luck
Ronin Panda's Avatar
i installed a momo monte carlo steering wheel and couldnt get the horn to work so i said **** it and removed the horn ..less weight too
Old Jan 9, 2004 | 01:58 PM
B18Cej1's Avatar
Default Re: honk button doesnt work (Ronin Panda)
i have a cable reel for sale.
Chris N's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ausmith &raquo;</TD></TR><TR><TD CLASS="quote">Honk button?</TD></TR></TABLE>
LOL! I love the terminology.
Old Jan 10, 2004 | 09:33 AM
hondamanwill's Avatar
stop bogarting and pass it along
Old Jan 10, 2004 | 09:38 AM
JSPECHB's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedHackBatch &raquo;</TD></TR><TR><TD CLASS="quote">my honk button doesnt work. is there a fuse or something that might be out??? or any one know what might be the problem??</TD></TR></TABLE>
Someone probably cut the wires that goto your horn planning on stealing your car. I would check that. Thiefs! Thats why I relocated my horn into my engine bay. Its louder also.
soysau5e
Mar 18, 2010 07:27 PM
Redemption
Jun 24, 2007 03:18 PM
TurboEM1
Nov 19, 2005 03:28 AM
Jdmbsixteen
Jun 3, 2004 08:39 PM
illusion
May 29, 2003 11:07 AM
