CTR Calipers - Anything Interchangable?
OK, I have a CTR 5 Lug setup on my EK. I'm pretty sure that my front calipers are gone. Do any more common calipers, like Si or GSR's bolt up?
Re: CTR Calipers - Anything Interchangable? (citrEK)
well if you could tell me the rotor size i could help you out alot more.
if they are 11.1 inch rotor's you can run 97+ ITR calipers, 92-97(??), and the 94 accord V6 caliper. or if you want to go to a 2 piston caliper you could run an early moldel NSX caliper. all these are for 11.1 inch rotors. if the rotors are 10.3 then you could use GSR.
with the adition of the NSX calipers you might run into clearance issues. im not sure though
Re: CTR Calipers - Anything Interchangable? (slammed_93_hatch)
not sure what CTR rotor size is.. bout half inch bigger or more then my stock 99 DX HB rotors. i need to find calipers ASAP if i need them, and have them installed before next friday.
I'm not sure if you have read this or not? Maybe some of the ideas might help you.
http://hybrid2.honda-perf.org/....html
Re: (USDMDC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDMDC2 »</TD></TR><TR><TD CLASS="quote">i have the slighest clue what size the ctr rotor is. goodluck man </TD></TR></TABLE>
wow thanks for the informative post
Re: CTR Calipers - Anything Interchangable? (Peagreenhatch)
i'm looking for as much of an OEM replacement as i can, the least expensive route since i need the car running BEFORE next friday. no, i didn't upgrade booster or master cylinder yet. plan on it near future, but can't afford it right now. just gotta get the car functioning for my 2000 mile trip.
Hit em up the ITR people who have gone Spoon then and see if they have their old calipers. Or hit up len at baranco acura for pricing on a new one. ITR calipers will work
Re: (94hatch)
PM sent, anyone else have any ideas incase this doesn't go through... i'm pinchin here and on a pretty low budget, any help would be appreciated.
Re: (citrEK)
if your in such a PINch why didn't you go messure your rotor's. your asking for all this help from us but you wont go messure your rotor's???
Now that i have that stright. Go to an auto parts store and purchase remanufactered stock calipers for an 97+ ITR, or a 92+ prelude VTEC, or 94+ V6 accord. i just did this same swap basicly and it was 50 bucks after the core charge for each caliper. the ones i got were Nissin (sp) same as stock ones from honda.
Re: (slammed_93_hatch)
OK, found out that my calipers are fine... but i am questioning the rear left trailing arm... here's a link....
https://honda-tech.com/zerothread?id=728715
GoldenONE
05-16-2003 11:43 PM
