Steering Wheel off center and brakes not catching til almost all the way down???
i am in the process of replacing parts on my car, test drove it today around the block. the steering wheel is turned almost so the H emblem in the middle is laying on its left side. also, my brakes don't apply til the brake is almost all the way on the ground, and when you press the brake, it makes almost a creaking spring noise.
when i hit the curb that caused all this mess, i slid sideways into the curb with the right side of my car and my wheel was kinda cocked to the left trying to turn out of it. the car turns fine, just that the wheel is sittin all stupid. any ideas, anyone?
Re: Steering Wheel off center and brakes not catching til almost all the way down??? (93 EJ1)
You might also try and bleed the brakes in all four wheels.....
Re: Steering Wheel off center and brakes not catching til almost all the way down??? (aw1234dude)
i am putting on new rear lca's this friday once they arrive, we bled the brakes over 2 times... started RR, then RL, then FR, then FL. furthest from master cylinder to closest. anyone have any idea what the popping/creeking spring noise from my brake pedal is? just installed earl's brake lines.
Re: Steering Wheel off center and brakes not catching til almost all the way down??? (citrEK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by citrEK »</TD></TR><TR><TD CLASS="quote">i am putting on new rear lca's this friday once they arrive, we bled the brakes over 2 times... started RR, then RL, then FR, then FL. furthest from master cylinder to closest. anyone have any idea what the popping/creeking spring noise from my brake pedal is? just installed earl's brake lines.</TD></TR></TABLE>
My car makes a little whining noise almost everytime I press the brakes a little hard while going slow and the pedal goes kind of low too. I wonder what this could be as well???
Adam
Adam
Re: Steering Wheel off center and brakes not catching til almost all the way down??? (AdamQ3B85)
maybe u need new brakes? New brake pads? Replace the lines. Brake Fluid?
I dunno, wow i'm a help.
RR => LF => LR => RF is the proper sequence to bleed your brakes. I'm not saying that is your problem, doing them wrong twice will get the job done.
Vice President/CEO
Re: (JMU1337)
brake master cylinder?
thats what it took to fix my brakes... exact same problem..
brakes did not stop untill pedal was floored, very crappy stopping.
Change out your Brake Master cylinder dood...
Re: (kKdARIAN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kKdARIAN »</TD></TR><TR><TD CLASS="quote">brake master cylinder?
Change out your Brake Master cylinder dood... </TD></TR></TABLE>
what on the MC to check?
Re: (citrEK)
if you pump the pedal a couple times and hold it, you should feel pressure on the pedal if its there only for a second or two you either have a leak or master cyclinder may be dying
dwllama
06-08-2017 02:23 AM
jag123
Honda Civic (2006 - 2015)
12-28-2010 07:54 PM
