Strange problem with rpm's....
for some reason if i try to hold the idle at like 3000 rpm with the clutch in...every few seconds it drops to 2000 then back to 3000....almost like a rev control or somethin....any ideas???
This is a 99 civic si with a vortech supercharger by the way
Re: (JDMlifestyle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlifestyle »</TD></TR><TR><TD CLASS="quote">vacum leak?</TD></TR></TABLE>
A vacuum leak would be evidnet at idle.
Re: (Ricey McRicerton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton »</TD></TR><TR><TD CLASS="quote">
A vacuum leak would be evidnet at idle.</TD></TR></TABLE>
is there any idle problems at idle? or just when holding steady at 3k?
Re: (GERM)
No problems at idle....it idles perfectly.....but when i try to hold the revs between 2000 and 4000 rpm, its like it cuts out every few seconds
Re: (GERM)
Is it just on your tach that it does this, or can you feel/hear the engine dropping? If you can actually feel the engine dropping, you'd probably get better help from the FI forum. Otherwise you may just not be running enough power to the tach (wiring too thin/worn out).
Re: (GsR HtCh)
still the factory ecu....im running the vafc hack. When i got the hack complete is when this started.
msd igniton so that should be fine
