will gsr front lower comtrol arms fit on a ek hatch
What the topic say. Will GSR front lca fit onto the 97 civic hatch. Can I still use my stock forks and also my bolts and bushings. Will everything bolt up.
Re: will gsr front lower comtrol arms fit on a ek hatch (wdskuk)
Umm Yea the GSR will fit your hatch but I would not recomend going with GSR LCA and swaybars go with the 99 Civic Si The Si bolts right up and it's actually lighter and you can fit th 99 Si swaybars also which is much bigger then the GSR
Re: will gsr front lower comtrol arms fit on a ek hatch (SIR-G)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIR-G »</TD></TR><TR><TD CLASS="quote">Umm Yea the GSR will fit your hatch but I would not recomend going with GSR LCA and swaybars go with the 99 Civic Si The Si bolts right up and it's actually lighter and you can fit th 99 Si swaybars also which is much bigger then the GSR </TD></TR></TABLE>
that is correct.. the GSR sway bar is 22mm, the SI is 26mm.. go figure.. but when you use the Si sway bar you'll need the forks and lca's from the SI also.. same setup i have on my 98 EK.
vaajboy
02-04-2006 06:40 PM
x00gsr
06-01-2003 06:15 PM
gubo22
11-12-2001 06:56 AM
