How to check CEL on '96 civic?
Re: How to check CEL on '96 civic? (rahman)
I can't remember if you can do that on OBDII hondas, but you can go to Autozone and have them pull the codes for free.
Re: How to check CEL on '96 civic? (Hella_JDM)
its a blue clip under the passenger side behing the plastic kick panel on the ground once u remove that u will see the ecu and then a blue plug tucked up there some place just put the paper clip in there from one whole to the other and then put the key in the ignition and turn to the on position the ecu light shoudl blink now if it was solid before the plug was in.
hope that helps
hope that helps
Re: How to check CEL on '96 civic? (SikCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SikCivic »</TD></TR><TR><TD CLASS="quote">its a blue clip under the passenger side behing the plastic kick panel on the ground once u remove that u will see the ecu and then a blue plug tucked up there some place just put the paper clip in there from one whole to the other and then put the key in the ignition and turn to the on position the ecu light shoudl blink now if it was solid before the plug was in.
hope that helps</TD></TR></TABLE>
So, the 96-00 is the same as the 92-95 civic's? Above describes the Eg perfectly....
My parents 98 LX CEL is on. Got to check it out in a few.
Re: How to check CEL on '96 civic? (yellow_jacket)
http://www.c-speedracing.com/faq/06.php Does anyone search at all??
Re: How to check CEL on '96 civic? (Ricey McRicerton)
hope this helps https://honda-tech.com/zerothread?id=727895
Re: How to check CEL on '96 civic? (NAB16AEK)
[<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SikCivic »</TD></TR><TR><TD CLASS="quote">its a blue clip under the passenger side behing the plastic kick panel on the ground once u remove that u will see the ecu and then a blue plug tucked up there some place just put the paper clip in there from one whole to the other and then put the key in the ignition and turn to the on position the ecu light shoudl blink now if it was solid before the plug was in.
by this i meant CEL light sry ...older cars have the light on the ecu
righteyeblind
06-30-2008 01:50 PM
wizzards581
12-20-2003 02:36 PM
