4040 prop valve replacement on EG
I'm doing a rear disk conversion on my 93 CX. I know the fittings on the master cylinder are different when converting to integra MC, but is this the same for the prop valve?
I've got an integra 4040 valve here, will the treads fit with no mod?
Re: 4040 prop valve replacement on EG (B18G)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18G »</TD></TR><TR><TD CLASS="quote">I'm doing a rear disk conversion on my 93 CX. I know the fittings on the master cylinder are different when converting to integra MC, but is this the same for the prop valve?
I've got an integra 4040 valve here, will the treads fit with no mod?</TD></TR></TABLE>
I believe it should fit, not too sure but I don't see why not.
1 Post
search!...
just one of the results:
https://honda-tech.com/zerothread?id=68721
chris
Modified by TeamNextGenChris at 4:15 AM 1/10/2004
chris
every thing should be a direct bolt on,if you choose a 40/40 from a car with abs your're gonna have to bend the lines to fit.i used a booster,master cyl,and prop.valve from a 96 integra rs .it bolted up with no problem
VBitter
10-14-2009 06:06 AM
midnightdarknes5
05-20-2004 11:59 PM
