clock went out
clock went out
ok guys sorry if this sounds stupid but i have no idea whats up. basically i got a sol and the clock for the sol is in the cluster. the clock started going out.. well actually dimming but when i presses the buttons (hour/minute) it would light up again. now it wont even do that its out cold. i was wondering could it be a bad fuse? or is it basically dead? also if i wanted to replace it could i replace just the clock or would i have to replace the whole cluster. thanks for the help in advance.
Re: (USDMDC2)
not sure if you fixed this already or not... but my friend just asked me the same question because the clock in his mom's Del Sol was doing the same thing. I couldn't really find an answer here on HT, but a search showed that there's a 7.5a "backup" fuse in your engine bay fusebox that's linked to the clock. That was the case in my friend's mom's car... HTH
Re: (B U N M A N G O)
thanx, ill check the engine bay fuse box today to see. One thing is though that the clock acts like its really dim... then when you hold down one of the buttons it lights up a little bit more and then when you stop holding down the button it goes away again. I fwould assume if it was a blown fuse it would be a white black, work or not work type of deal. then again it could be a loose fuse or a bad fuse so i will check. thanx for the help guys
Re: (1C9R9X3)
the same thing is happening in my hatch
the clock doesn't come on but if you press that lil button on the right side of it it lights up but when i let go of the button the clock goes away
clean_sol
02-19-2011 02:03 PM
