engine problems
Old May 7, 2004 | 09:55 PM
blackflag188's Avatar
Default engine problems
I bought an ek hatch the otherd day with a b18c in it. Well everything seemed fine until i got it home i looked over everthing and i realize that theres oil on the top and bottom of the spark plugs, no coolant, barely any oil (keep in mind i drove this **** an hour and a half back to my house, and for some stupid reason i didnt check that **** before i got the damn car). So i took my old accord to work today got back and desided i was going to clean up some of the oil out of the spark plugs, so i soaked it all up and put it back together. Started the car and smoke was coming out the tailpipe like a ****. So i got a couple questions: First what should i do about the spark plugs? replace spark plug gaskets/valve cover o rings? and second why is it smoking so much, the smoke is like a blue/white color.(it wasnt smoking last night on the drive home)
Modified by blackflag188 at 11:35 PM 5/7/2004
Old May 7, 2004 | 10:20 PM
garlic jr's Avatar
Default Re: engine problems (blackflag188)
soap ? then u put it back in ? LOL
oil on the spark plug is blow by from bad rings... or in some cases if your lucky u will just splash it on the plug, clean it, and never see it again...
back when this happened to me in my stock setup i took the plug out and replaced it with brand new 1, also drained the oil and changed it.. i have yet to ever see oil on my plugs again....
wasant very smart of u to use soap even if u dry it off.. now you better just plain replace the plugs and wires and that will fix your problem, clean out the firing chamber with a rag and extensioner, get all of the oil out.
Old May 7, 2004 | 10:35 PM
Default Re: engine problems (garlic jr)
sorry I cant spell worth a ****, I soaked up all the oil. Did NOT use soap haha
1992honda
Jul 26, 2011 05:42 PM
vtec_lude
Sep 18, 2006 08:20 PM
sacredc0w69
May 24, 2003 06:34 AM
chirp2hrd
Jan 24, 2003 08:19 AM
Digital-R
Aug 3, 2001 11:07 AM
