IAT location?????
IAT location?????
Yah, I've got a 93hatch dx with a gsr swap. I'm showing a cel, Its one long flash...I believe thats a code 10, IAT.. anyone know were this is located and can I do anything to correct it? pics would be cool. thanx in advance.
Re: IAT location????? (pnltnc)
the IAT sensor is the sensor on the manifold that is located to the left of the fuel pressure regulator and right above the fuel rail...not sure what to do to correct it though..maybe get a new one?
Re: IAT location????? (FBPsi7)
Double check your wiring to make sure you don't have a short from a bad wiring job and if the wiring is good then just replace the IAT. If that doesn't fix it then make sure your ecu isn't fucked up. You can tell if you have a burned spot on your ecu board somewhere.
axhandler
06-18-2003 08:33 AM
