NEED HELP INSTALLING TRANNY FROM ANYONE WITH EXPERIENCE
Is it me or is it ****** impossible to put the tranny back on the block.Need tips on how you guys get it back on!
Thanks
Thanks
Re: NEED HELP INSTALLING TRANNY FROM ANYONE WITH EXPERIENCE (rocco)
are you sure you got the pins aligned? make sure nothing is in the way, is your clutch alligned?
Re: NEED HELP INSTALLING TRANNY FROM ANYONE WITH EXPERIENCE (ABK)
well i used a clutch alignment tool so it should be aligned,is it usually hard to pus a trany back?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rocco »</TD></TR><TR><TD CLASS="quote">well i used a clutch alignment tool so it should be aligned,is it usually hard to pus a trany back?</TD></TR></TABLE>
Nope, usually fits together like a puzzle.
Re: NEED HELP INSTALLING TRANNY FROM ANYONE WITH EXPERIENCE (hOnDadiCt)
Just make sure you're putting it on evenly. And keep wiggling/sliding it. It may take you 15 minutes of wiggling to get it on there, but eventually it should slide back in.
Re: NEED HELP INSTALLING TRANNY FROM ANYONE WITH EXPERIENCE (Ricey McRicerton)
yeah I never done it while the engine is still inside the engine bay, but you need to wigle it around while pushing on it.
its easyer with 2 people, have one person "bench Press" the tranny on his chest, while the other person guides it from the top, works well, just wiggle that ****.
Re: NEED HELP INSTALLING TRANNY FROM ANYONE WITH EXPERIENCE (WangChung)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WangChung »</TD></TR><TR><TD CLASS="quote">how much does the average Honda tranny weigh?</TD></TR></TABLE>
The B and H were proved to weigh 100 and 123 lbs respectively.
The D weighs less than either of those.
is the imput shaft going in at all? do you have a half shaft? is the clutch aligned properly?
make sure it is going in striaght the splines will not go together if it is going in at an angle, and when it is in do not let the trans rest there w/out bolst being in it or the mount on and hooked up.
Re: NEED HELP INSTALLING TRANNY FROM ANYONE WITH EXPERIENCE (xerox445)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xerox445 »</TD></TR><TR><TD CLASS="quote">its easyer with 2 people, have one person "bench Press" the tranny on his chest, while the other person guides it from the top, works well, just wiggle that ****.</TD></TR></TABLE>
This is what worked for me and a freind.
Re: NEED HELP INSTALLING TRANNY FROM ANYONE WITH EXPERIENCE (JDM_Bug)
One time I was trying to get the tranny back onto my friends Impreza 2.5RS and I just couldnt get the damn thing on for the life of me. I literally spent about an hour benching the bitch up onto the car and trying to wiggle it in. The input shaft would go most of the way in and then would stop. After getting extrememly frustrated I pulled the tranny all the way off to look at the clutch. I used the alignment tool that came with the clutch kit to align the thing but the tool was so shitty and loose that the clutch wasn't exactly straight with the pilot bearing on the flywheel. I ended up realigning the clutch and threw the tranny back on in less then 10 minutes.
Yeah that pissed me off for about a week.....
thats the way we do it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton »</TD></TR><TR><TD CLASS="quote">The B and H were proved to weigh 100 and 123 lbs respectively.
The D weighs less than either of those. </TD></TR></TABLE>
thats amazing cause i have shipped a few B series transmissions and it comes out to under 90lbs packed.
around 88lbs for a B series.
Usually the problem is that the input shaft isn't ligning up with the clutch friction plate. Either you didn't align the clutch before tightening it down, or you just need to wiggle the tranny around a little more.
Tranny jacks, brute strength, or a couple friends definitely make things easier.
Re: NEED HELP INSTALLING TRANNY FROM ANYONE WITH EXPERIENCE (Kamin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kamin »</TD></TR><TR><TD CLASS="quote">
around 88lbs for a B series.</TD></TR></TABLE>
Maybe those were the blocks then.. on me. I was referring to the B vs. H weight thread and got the block confused with the tranny. Thanks for being on top of things Kamin.
EDIT: STREETWERKZ and cxSHOE both of you bickering are destroying a legitimate thread. Keep it on topic and your childish arguments in PM or you WILL be loosing points. Please delete your comments from the thread if they are not pertaining to the topic. If they are not deleted, I will do so and will dock points.
EDITx2: https://honda-tech.com/zerothread?id=684550
There's the thread. Check out the tranny weights in there.
