Del Sol VTEC axle back on EG w/ B16A
I'm looking for a stock exhaust to remove my loud apexi axle back. I was told the Del Sol VTEC axle back would fit on the 92-95 HB. But is the diameter different than the 92-95 Si exhaust. (1.90 in) Also, I guest I would'nt lose a lot of power with this exhaust... (Have a B16A2 w/ intake only)
Any input is appreciated...
Thank you
Thank you
Re: (92b16vx)
Well the mid-pipe is shorter, but the axle is the same. But I wanted to know if the diameter is bigger than the Stock 92-95 Si HB exhaust. From the information I got, the 92-95 Si is 1.90 in. I imagine the one on the Del Sol VTEC would be slighty bigger... something like 2.0 in.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92b16vx »</TD></TR><TR><TD CLASS="quote">Axle back should fit, the Civic hatch is 8" longer than the Del Sol, so more than that and you'd come up short.</TD></TR></TABLE>
Re: (Beeline)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Beeline »</TD></TR><TR><TD CLASS="quote">Well the mid-pipe is shorter, but the axle is the same. But I wanted to know if the diameter is bigger than the Stock 92-95 Si HB exhaust. From the information I got, the 92-95 Si is 1.90 in. I imagine the one on the Del Sol VTEC would be slighty bigger... something like 2.0 in.</TD></TR></TABLE>
I doubt it makes a difference, since in the rest of the world the Civic received the B16A also. Not to mention most people have wider diameter aftermarket exahust anyway.
Re: (92b16vx)
Thank 92B16vx...
But I think a 1.90 in exhaust may be too small for a B16a. The 99-00 Si came with a 2.0 in exhaust. I still have my stock piping from exhaust to axle back.
I'm simply tired of my Apexi N1 exhaust (welded to stock axle back) and I don't want to modify an ITR or GSR exhaust to make it fit.. So my only choice is the 92-95 Si or Del Sol VTEC exhaust...
Thanks
Thanks
CKPerformance
14
09-12-2007 10:54 PM
KyleVA
02-17-2007 07:02 AM
Happyman
11-01-2003 05:01 PM
kay_animation
02-03-2003 06:04 PM
