Can you put a B16 LSD in a USDM LS tranny?
Can you take the SIR2 B16 LSD's and put them in any B series tranny's or can they only go in the B16 tranny's?
Re: Can you put a B16 LSD in a USDM LS tranny? (92SIvic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92SIvic »</TD></TR><TR><TD CLASS="quote">i BELIEVE so..</TD></TR></TABLE>
Re: Can you put a B16 LSD in a USDM LS tranny? (Del_Slowest)
this looks like a KAAZ or some other LSD.
92-00 JDM LSDs from a B16a usually have 12 bolts on the FD, which does not work or interchange but this is different so it looks to be aftermarket or Teg diff, which uses the proper : 10bolt pattern
Re: Can you put a B16 LSD in a USDM LS tranny? (eg6ajk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6ajk »</TD></TR><TR><TD CLASS="quote">this looks like a KAAZ or some other LSD.
92-00 JDM LSDs from a B16a usually have 12 bolts on the FD, which does not work or interchange but this is different so it looks to be aftermarket or Teg diff, which uses the proper : 10bolt pattern</TD></TR></TABLE>
you're very good. it is a KAAZ LSD, i just put a picture in here so ppl would look at the thread. i'll look tonight and see if it's a 12 bolt, if it is then i'm screwed....right?
