What E-Brake cable on eg hb with del sol disk brakes???
Hey guys I have a 93 hb. I recently did a all wheel disk swap on it. The brakes came off a Del Sol. I was wondering which E-Brake cable I am supposed to use??
Anyone know? Thanks.
Re: What E-Brake cable on eg hb with del sol disk brakes??? (h22Hatchy)
search next time https://honda-tech.com/zerothread?id=152884
Re: What E-Brake cable on eg hb with del sol disk brakes??? (96hatchback)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96hatchback »</TD></TR><TR><TD CLASS="quote">search next time https://honda-tech.com/zerothread?id=152884</TD></TR></TABLE>
That thread is horrible.
I used 99 si ebrake cables on my 92 cx.
Had to move the mounting clips around a bit,
but they worked fine.
Why cant you use the ebrake cables thaet came with
your swap? Did you not get any? If you didnt and have
to go buy some the common sence answer would be to
get rear disc cables from your chassis, so that would
be the si hatchback.
Re: What E-Brake cable on eg hb with del sol disk brakes??? (elwood)
Yaa mine did not some with cables. I didn't know which ones to use because I heard I can't use the del sol, cause there to short . I heard I can use integra or civic si. Thanks guys.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22Hatchy »</TD></TR><TR><TD CLASS="quote">I heard</TD></TR></TABLE>
Thats the thing with brakes. What you have heard is usually
wrong, thats why I tried the 00si cables, turned out fine for me.
you can also use 92-95 civic si rear cables. If you are interested i have a brand new set for sale (still in the boxes)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22Hatchy »</TD></TR><TR><TD CLASS="quote">Yaa mine did not some with cables. I didn't know which ones to use because I heard I can't use the del sol, cause there to short . I heard I can use integra or civic si. Thanks guys. </TD></TR></TABLE>
you can use the del sol ones you just have to extend the ebrake bar thing lol if you look at it you will know what i am talking about
TSPeed Factory
Re: What E-Brake cable on eg hb with del sol disk brakes??? (B16B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16B »</TD></TR><TR><TD CLASS="quote">you can also use 92-95 civic si rear cables.</TD></TR></TABLE>
the 100% way to get the best fitting cables.
1sikhatch
07-16-2009 03:06 AM
ghost95delsol
09-26-2006 12:34 AM
275Performance
02-08-2004 06:56 AM
