engine starts revving
This just started a couple days ago...when I first start up my car...the car rev's to about 2 grand...and stays there....then takes about 10 minutes before it idles back down to 900rpm's. Any clue on what's going on? Thanks in advance.
Re: engine starts revving (stella99si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stella99si »</TD></TR><TR><TD CLASS="quote">check your vacuum lines, something might be disconected</TD></TR></TABLE>
That would give him an erratic idle
Re: (EG9_519)
here's another crazy problem it's doing.......when I let the clutch out...the rpms's pick up about 500 rpm's.....
This has me mind-boggled
Please help
Please help
Re: engine starts revving (otakueric)
Take that bitch, out and get some throttle body cleaner, and spray that **** inside and go crazy, It will help out the idle a lot, if you do this. If you want to be **** about it, take the intake manifold and clean that too, the car will idle like new.
Re: engine starts revving (spoon92hatch)
check your belts. my friend had the same problem but his idel would not go down. He took the ac belt off and now it idels normal.
Global Moderator
Re: engine starts revving (spoonbenny)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoonbenny »</TD></TR><TR><TD CLASS="quote">Take that bitch, out and get some throttle body cleaner, and spray that **** inside and go crazy, It will help out the idle a lot, if you do this. If you want to be **** about it, take the intake manifold and clean that too, the car will idle like new.</TD></TR></TABLE>
Don't spray alot of cleaner into your intake manifold.
Spray the cleaner on a type of swab or cloth and wipe around.
Spraying to much into the intake manifold will result in check engine lights and your car not wanting to start until some of the cleaner evaporates.
Be careful and let us know
Re: engine starts revving (Usdmdc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by otakueric »</TD></TR><TR><TD CLASS="quote">how do you clean the tb?</TD></TR></TABLE>
should be 4 nuts holding it on...take them off, unhook your intake tubing and undo your throttle cable...pull it off and use brake cleaner or some sort of highpower degreaser or something and wipe all that shiizzz down and slap it back on.
Re: engine starts revving (sohcvtec1995)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcvtec1995 »</TD></TR><TR><TD CLASS="quote">check your belts. my friend had the same problem but his idel would not go down. He took the ac belt off and now it idels normal.</TD></TR></TABLE>
why would the ac belt make a difference?
