Noises from suspension i think.... SOMEBODY HELP ME!!!!
ok..heres the problem, whenever i turn or but on the brakes semi-hard, i hear this loud thud click type sound coming from it sounds like right underneath my drivers side seat...i have a 93 civic HB with ground effects lowering springs....if anybody can help troubleshoot the problem id appreciate it....could it be i need brakes? Or is it just the suspension is too tight...or what....maybe a bushing????
I NEED HELP....thanks
Trevor
Trevor
Re: Noises from suspension i think.... SOMEBODY HELP ME!!!! (poppycock)
my moms chrysler cirrus does this *** well, i was thinking maybe the LCA's got screwed up, or the springs.. i have no basis for either of those thoughts.. but, im interested to see what others think, then maybe i can help my mommy out
Only thing I can think of is check you axle. But I might be wrong. A friend had this problem when he turned or braked his axle would make thumping or thud sounds similar to what your describing. Oh well I tried.
Re: Noises from suspension i think.... SOMEBODY HELP ME!!!! (Hammett)
i have the same problem when i brake hard makes like a click i just replaced my axle im gonna go check my caliper it was removed before and i dunno if it was properly torqued. oh well i would like to hear more suggestions as to what might be wrong.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hammett »</TD></TR><TR><TD CLASS="quote">yea.. i think its the axle too..</TD></TR></TABLE>
Re: Noises from suspension i think.... SOMEBODY HELP ME!!!! (AzntaggeR)
yeah, that would be my guess if it were only in the front, is it?? The reason i didnt think that way, is, in my case, my moms car clunks in front, and back.. so, therefor it wouldnt be the axles
Re: Noises from suspension i think.... SOMEBODY HELP ME!!!! (aphex23)
It sounds like it would be your axle. However, I recently had a similar problem, and it ended up being the heat sheild behind my rotor.. It had somehow became bent and was rubbing up against my rotor when I would apply my brakes and turn sharply.. Although it sounded like it was coming from under my passengers seat.
It may not be the same problem for you, but I would get it checked out and make sure it's not unsafe to drive. Good luck.
^LORTA^RACING
07-24-2008 03:37 PM
