Rear sway bar question
I have a 1992 civic hatchback (si) and would like to put a strong swaybar on the rear. The only problem that I can see is that there is no factory rear swaybar to use as far as mounting points. Can I still put a rear swaybar on my car with keeping the factory rear lower control arms? I planned on using the rear subframe brace also. Any help is appriciated.
Re: Rear sway bar question (cu_jarrett)
Neuspeed, Progress, and Suspension Techniques show applications for all '92-'95 Civics, so I'm assuming you'll be okay. My EJ8 doesn't have a factory rear ASB, either, and my Progress installed just fine. The Suspension Technqiues Speedtech kit looks beefy, though! Looks like it comes with its own subframe bracing. http://www.modacar.com/Merchan...W.jpg
Re: Rear sway bar question (jL iLLuZiOnz 9)
So drilling a hole in me RLCA wont hurt anything?
Withc sway bar do you reccomend? I was thinking the cusco 26mm.
With what little information you've disclosed, nobody can make a judgement call on what swaybar you should run. Do a search, then maybe reply to this, saying what you're looking for.
I have a Comptech set-up, FWIW.
auto addict
07-06-2008 12:47 PM
EK99hatch
09-15-2006 07:32 AM
tinkfist
08-23-2002 06:52 AM
keithv
08-08-2001 09:30 PM
