Is this a 1" MC? Picture.
Came off of a '98 GSR w/ABS. That's the only number I see on the MC, but people have told me the size marking is on the OTHER side of the MC.
I've tried searching but some threads say only the ITR has a 1" MC while the Integras with ABS are slightly smaller, but then others say the 98+ Integras with ABS all have a 1" MC.
The other side just has a B C 5 and then Honda.
TIA for this seemingly simple question.
Re: (Turbo E 604)
not unles you swap out the matching brake booster, and even then youneed to reflare i beleive one of the lines unless you are really good t carefully bending brake lines to get it to the new position on the m/c
Re: (Turbo E 604)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo E 604 »</TD></TR><TR><TD CLASS="quote">now will it fit on an EG?</TD></TR></TABLE>
It fit in my EG hatch...All we did was swap out the MC and BB and then bend one of the lines carefully to make it fit
Re: (Derek14)
that looks exactly like the mc/bb combo i have in my car. check the two threaded holes, they will either be one 10 mm, and one 12 mm. OR both will be 10 mm. If they are both the smaller size, you're in luck and won't have to reflare your lines, all you need to do is bend them which is pretty easy.
my mc/bb is from a '99 gsr
Re: Is this a 1" MC? Picture. (NextelBuddy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NextelBuddy »</TD></TR><TR><TD CLASS="quote">you see that big <FONT SIZE="10">1</FONT> ?
yup thats it</TD></TR></TABLE>
Thanks for the help
I was just double checking because on my EF the number is on the left side of it, and I just wanted to double check.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Derek14 »</TD></TR><TR><TD CLASS="quote">from a GSR? thats an ITR MC/BB combo...</TD></TR></TABLE>
I pulled this myself off of a '98 GSR w/ABS.
I was under the idea that the 98+ Integras with ABS had the same setup as the ITR.
Is this not the case?
Thanks for the help
TSPeed Factory
Re: (Okininam)
you're better off just finding an integra RS master cylinder/brake booster or a 91 civic EX. they're both 15/16" and you don't have to hassle with rebending and reflaring brake lines.
nikolai.
12
11-12-2006 08:51 AM
