Tein SS Coilovers - After Install ?
Old 05-22-2004, 06:44 AM
phreakmang's Avatar
Default Tein SS Coilovers - After Install ?
All 4 are like this, here are pictures of the front 2.
Perhaps a missing washer?
Old 05-22-2004, 06:52 AM
hayabusa160's Avatar
Default Re: Tein SS Coilovers - After Install ? (phreakmang)
did u forget the bottom rubber piece?
theres a washer under the rubber pirce too you forgot one of them
Old 05-22-2004, 07:31 AM
BlownVR's Avatar
Default Re: Tein SS Coilovers - After Install ? (hayabusa160)
They should not be that high up. I think your missing a washer on the bottom part.
Old 05-22-2004, 07:32 AM
Brewer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hayabusa160 &raquo;</TD></TR><TR><TD CLASS="quote">theres a washer under the rubber piece too</TD></TR></TABLE>
Washer is missing.
Old 05-22-2004, 07:56 AM
Civiclx's Avatar
Default Re: Tein SS Coilovers - After Install ? (BrewerHatch)
yeps, the washer that is missing is the one that goes right under the stock metal dust boot right where the shock rod thins out
Old 05-22-2004, 09:16 AM
phreakmang's Avatar
Thanks a lot.
Happen to know off the top of your head what size washer that i'll need?
And this will not require me to take the actual springs back off will it?
Old 05-22-2004, 09:20 AM
.ShawnD.'s Avatar
its not just any washer its the one that sits on the shock rod that holds the rubber pieces in place and doesnt alow them to move down further.. and yep.. gonna have to take them all back off : good luck
Old 05-22-2004, 09:23 AM
phreakmang's Avatar
Default Re: (.:s h a w n D:.)
hrmm...shat.
really need to know where i can get this mysterious washer. a site on the net, or exact size/type.
it shall be fixed.
Old 05-22-2004, 09:28 AM
.ShawnD.'s Avatar
what happend to the ones on either your old shocks or your new ones
Old 05-22-2004, 09:30 AM
Brewer's Avatar
Yeah, you should've reused the washers from your stock stuff.
Old 05-22-2004, 09:35 AM
H-T White Ops
Frozen E's Avatar
I did the same thing. It's that fat silver washer that has a taper in it. Gotta get it from honda. It sits over the tapered part of the shaft. Don't drive around like that.
::Edit::
I believe it's #13
http://www.hondaautomotivepart...ORBER
Old 05-22-2004, 09:46 AM
phreakmang's Avatar
Default Re: (IslandSi)
*shrug*
I didn't put them on, and no longer have the old shocks.
Thanks a lot, anyone else agree it's part #13 for both rear and front?
Old 05-22-2004, 09:54 AM
H-T White Ops
Frozen E's Avatar
You should go beat the hell out of whoever put them in.
Just doubling up on what I said, they're SPECIAL washers. Tapered hole. Go to honda and have them order you some overnight. Shouldn't be any more than a few bucks extra. The only part that sucks is that you have to pull the shocks back out like you were doing a complete suspension swap again.
Old 05-22-2004, 09:56 AM
phreakmang's Avatar
I was just going to order them from the site, honda dealers around here are a hassle to work with.
Even though majestic honda is a bit slow sometimes.
Old 05-22-2004, 10:07 AM
hatchii's Avatar
Default Re: (phreakmang)
yea you are missing the washer, i did the same thing too. haha
jmai86
Suspension & Brakes
06-13-2008 05:23 AM
jsgcivic03
Honda Civic (2001 - 2005)
06-04-2008 11:55 AM
RACEPAK
Suspension & Brakes
02-10-2005 02:39 PM
Jaypee
07-21-2004 04:50 AM
sleepyhamsterlx
11
05-07-2003 08:20 PM
Quick Reply: Tein SS Coilovers - After Install ?
