Burning oil????
Burning oil????
My cousins civic si (canandian) with the D16Y8 is loosing oil. He had a oil change dun a week and half ago and now his level is a little below the bottom hash mark on the dipstick. he's puffin smoke at high RPM but other then that it seems fine. there are no visable leaks in the engine bay. anyhelp or thoughts of what it is would help. thanks
Re: Burning oil???? (EJ8GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ8GSR »</TD></TR><TR><TD CLASS="quote">search</TD></TR></TABLE>
At least he explained his problem in a coherent mannar and used punctuation.
How many miles (Km) does it have? Sounds like the engine might be getting tired. How many miles since the oil change? Has it ever burned oil before now? Most hondas do, I know my Y8 goes through 1/2 - 1qt between oil changes.
Check the bottom of the oil fill cap, see if there's any foam or residue. Do a compression test, and if you have compressed air available, a leakdown test. That should narrow things down a bit for you.
Re: Burning oil???? (EX_AutoXer)
The car has about 140,000KM on it ummm its been burning slight oil for a while but not this much. I'll go thorough what u mentioned and see if i can narrow it down. Thanks for the info.
bigslimdog
42
03-27-2004 03:02 PM
