injector wires in the harness. which one is which??
last night while installing my inline resistors my friend wound up cutting all 4 yellow/black wires for the injectors just shy of the harness on the drivers side strut tower at the same time. i need to know exactly which wires coming out of that harness correspond to which injector, so i can wire the resistors in and have everything matched up. i can figure out which ones comming off the injectors are what, but i need them off the harness. sorry for such a stupid specific question
Re: injector wires in the harness. which one is which?? (blackeg)
Easy take your injector wires and match them to the plug where it connect at the passenger shock tower, the black yellows are all Battery voltage So if your friend cut off all the black yellows then dont worry just put them in any order the ones you have to worry about are the ones that go to the passenger side they are the ones that are controlled by the ecu by grounding them
Re: injector wires in the harness. which one is which?? (BatuKing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BatuKing »</TD></TR><TR><TD CLASS="quote">Easy take your injector wires and match them to the plug where it connect at the passenger shock tower, the black yellows are all Battery voltage So if your friend cut off all the black yellows then dont worry just put them in any order the ones you have to worry about are the ones that go to the passenger side they are the ones that are controlled by the ecu by grounding them</TD></TR></TABLE>
thanks man. ill solder them resistors in tomorrow
