Integra dash people HELP!!!
MY swap is basicly done i just ran into a few problems.
1. my tach doesn't work, even before the dash swap i tried putting in a aftermarket tach because i didnt have a stock one and it still didnt work. I was wondering if i have a to add a wire or somthing. the car is a 92 hatchback dx.
2. my speedo doesn't work.
3. my clock and radio don't work> i checked the fuse for the radio and cig lighter and its fine. the cig lighter even works!
Info: 92 hatchback dx
GSR dash and harness, i moved the 2 wires to the green plug and matched the rest of the pinouts with the stock civic grey plug.
any help would be appreciated...
Re: (hialeahzbg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hialeahzbg »</TD></TR><TR><TD CLASS="quote">i wood like 2 put a teg dash on my eg it will fit perfect and i will also need the door panels rite?</TD></TR></TABLE>
fitment is based on how patient you are...mine yea its about perfect. and for the door panels i am still working on them but i am cutting them and refiberglassing...also i built up a foam ramp where the panel meets the dash up top because the door panel sat lower then the dash.
still need help guys
Re: (HybridHatchC1)
did anyone ever make a diagram of what should be pinned in the civic grey plug when doing the swap? still having troubles people
Re: (HybridHatchC1)
clock and radio wont work if you dont have constant power running through the yellow wire.. test that and see if it does.. it should always be a source of power.. so that should solve that problem.. as far as the speedo i dont want to just start guessing.. i did this swap to my hatch like 2 years ago and it always had bugs. when one thing fixed another would bug out.. all i can say is make sure the harness has a GOOD ground
Re: (drunknbass)
i have like 3-4 wires that dont match(or the civic fuse box plug doesnt have) Orange which is speedo, a blue and red wire, and a tealish green wire. i check the yellow everything is fine.
Re: (HybridHatchC1)
can somone just take a picture of their gray plug...also where are the grounding locations for this harness, i am still haveing problems people
Re: (HybridHatchC1)
Was your tach/speedo working before?
All I did for my swap was tap power for the hazards. And for the 3rd plug that doesn't just plug right in... i trimmed the 2 extra pinouts that would keep it from fitting and just stuck it in there.... works.
Re: (splitime)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by splitime »</TD></TR><TR><TD CLASS="quote">Was your tach/speedo working before?
All I did for my swap was tap power for the hazards. And for the 3rd plug that doesn't just plug right in... i trimmed the 2 extra pinouts that would keep it from fitting and just stuck it in there.... works.</TD></TR></TABLE>
gotcha but i fucked the integra plug up... now i repined the stock gray plug everything is in the right place but... there are 3 wires that dont have a place, 1st.a solid yellow 2. a blue with red strip(cruise control?) 3rd. the abs? i know i dont need Cruise control or ABS, but i dont know what to do with the solid yellow. even though i still think my clock and radio should work. and aleast the speedo.
My car never had a tach to begin with/but the speedo worked just fine.
maybe its the grounds? anyone know where the harness should be grounded? also should i run a new tach signal wire? i dunno i am getting really frustrated and fed up with it. i would just like some help to get this done. thanks for all the posters in this thread.
Re: (JDMH22HATCH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMH22HATCH »</TD></TR><TR><TD CLASS="quote">Damn buddy, still having problems? Give me a call tonight and we can go over the pinouts from my car and yours. 214-766-2517
Brandon</TD></TR></TABLE>
i will take the offer, i guess i will give you a call tommorrow in the evening and see if we can work this out.
HybridHatchC1
05-19-2004 04:46 PM
