difficulty of vafc install?
Re: difficulty of vafc install? (otakueric)
Depends on your ecu...
With a p28 it took me about an hour and a half, including prep. Went thru and labeled all the wires, made myself a diagram, etc...
For the p28 you have to splice into 7 wires. If you've done any electrical work it'll be cake, so long as you TAKE YOUR TIME and check EVERYTHING...
Re: difficulty of vafc install? (igyloo)
Soldering is a good idea, but I'd hook it up with tap splices first if you're not sure. I tap spliced 'em, and am going to solder them when I get around to it, but if you do a wire wrong it's easier to undo a tap splice than desolder...
Re: difficulty of vafc install? (ShakesTheKlown)
you can always use THIS! no soldering or splicing and it will install in minutes! you can get it from http://www.aj-racing.com in vancouver, canada!
Re: difficulty of vafc install? (spoonbender)
For 170 bucks? That better be in canadian, and that better be negotiable. that's 20 bucks worth of connectors and wire that anyone with a detailed How-To could make...
Or you could actually be proud of yourself and do some actual WORK on your car...
i did my vafc and rev speed meter with g sensor and shift light in about 45 min on a p30 in my sol. i use the male female butt connectors incase something messes up then i can fix on the road with no problems. get one they are great and don't forget the rev speed meter too
Officer
12-22-2002 01:17 PM
