Jumping idle while stopped.
I THINK this only happens when I'm stopped and its hot (like today) and the fan is kicked on. The cars idle jumps to about 1500 then back to 1000 repeatedly. Any ideas? (JDM d15b)
Thanks
Thanks
Re: Jumping idle while stopped. (=GAMEOVA=)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by =GAMEOVA= »</TD></TR><TR><TD CLASS="quote">vaccuum leak, IACV, loose FITV.</TD></TR></TABLE>
English please? Where should I look for these problems/what are they? Thanks
Re: Jumping idle while stopped. (Erod)
check your vac lines. the iacv is the little black film container looking thing on your intake.rmeove it and clean it out.
OMFG do a search this damn thing gets covered at least once a day
number 9/11
edit: i got it mixed up number 14
Modified by H22A EG6 at 4:06 PM 5/23/2004
number 9/11
Re: Jumping idle while stopped. (H22A EG6)
i dont think number 9/11 is the idle air control valve buddy.
IACV:
take it out, i think its 2 10mm bolts, and two hoses clamped on the bottom
Then when its out, just spray it with carb cleaner and clean it. its recommended that you change the gasket too.
IACV:
i had the same exact problem as you did...and the problem was...that your throttle cable was too tight. (seriously) loosen it up and it'll idle back to 800 rpm
