del sol swap
del sol swap
First, what is the chassy code for my 96 del sol (im retarded) is it EH or EG or what?
Second, i am buying a 1st gen JDM b16a engine with no ecu or wireharness. What ecu should i buy, is the 1st gen OBD1 or 0. Im a noob at ecu's, also should i get a used or new wireharness, does it matter? Will i need new shift linkage when i pt it in my sol?
Re: del sol swap (BrianDelSol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrianDelSol »</TD></TR><TR><TD CLASS="quote">First, what is the chassy code for my 96 del sol (im retarded) is it EH or EG or what?
Second, i am buying a 1st gen JDM b16a engine with no ecu or wireharness. What ecu should i buy, is the 1st gen OBD1 or 0. Im a noob at ecu's, also should i get a used or new wireharness, does it matter? Will i need new shift linkage when i pt it in my sol?</TD></TR></TABLE>
The code is = ekeg465. [/end sarcasm] ....... New shiftlinkage ? does the swap not come with it or are you asking do you need to custom the shiftlinkage? you makes lots of sense
Re: del sol swap (jdm_loser)
You can run a P30 or chipped P28.
You need a shift linkage out of a Del Sol Vtec (B16a3 del sol)
The easiest way to tell if a motor is OBD0 is too look at the thermo housing and see if it has a coolant temp sensor on it if it dosn't it is on the back of the block and it is a OBD0 motor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_loser »</TD></TR><TR><TD CLASS="quote">
The code is = ekeg465. [/end sarcasm] ....... New shiftlinkage ? does the swap not come with it or are you asking do you need to custom the shiftlinkage? you makes lots of sense </TD></TR></TABLE>
n00bs talking **** to other n00bs. Don't be a ******* because you don't know what your talking about
Chassis Motor Origin Year Vehicle
4G (1988-1991)
ED3 1.5L USDM All 4-door DX/LX
ED4 1.6L USDM All 4-door EX
ED6 1.5L USDM All 3-door Standard
ED7 1.6L USDM All 3-door Si
ED8 1.5L USDM All CRX standard / HF
ED9 1.6L USDM All CRX Si
EE2 1.5L USDM All Wagon
EE4 1.6L USDM All Wagon 4WD
EF1 D13B JDM All Civic ?
EF2 D15B JDM All Civic ? / CR-X
EF3 n/a JDM All Civic ? / CR-X Si (ZC DOHC)
EF6 D15B JDM All Civic ? / CR-X
EF7 n/a JDM All Civic ? / CR-X Si (ZC DOHC)
EF8 B16A JDM All Civic ? / CR-X
EF9 B16A JDM All Civic ? / CR-X
5G (1992-1995)
EG1 D15B JDM All 3-door/4-door/CR-X
EG1 D15B8 USDM 1993-1995 del Sol (8-valve)
EG1 D15B7 USDM 1993-1995 del Sol S (SOHC)
EG1 D15Z1 USDM 1993-1995 del Sol VTEC-E (SOHC)
EG2 B16A JDM All 3-door/4-door/CR-X
EG2 B16A3 USDM 1994-1995 del Sol VTEC (DOHC)
EG3 D13B JDM All 3-door/4-door
EG4 D15B JDM All 3-door/4-door/CR-X
EG5 n/a JDM All ? (ZC DOHC)
EG6 B16A JDM All 3-door/4-door/CR-X
EG7 D13B JDM All 3-door/4-door
EG8 D15B JDM All 3-door/4-door/CR-X
EG8 D15B7 USDM All 4-door DX/LX
EG9 B16A JDM All 3-door/4-door/del Sol CR-X
EH1 n/a JDM All 4-door/4WD (ZC DOHC)
EH2 1.5L USDM All 3-door CX/VX/DX
EH3 D16Z6 USDM 1993-1995 3-door Si
EH6 D16Z6 USDM 1993-1995 del Sol Si (SOHC)
EH9 D16Z6 USDM All 4-door EX
EJ1 D16Z6 USDM All 2-door EX
EJ2 1.5L USDM All 2-door DX
6G (1996-2000)
EG1 D15B8 USDM 1996-1997 del Sol (8-valve)
EG1 D15B7 USDM 1996-1997 del Sol S (SOHC)
EG1 D15Z1 USDM 1996-1997 del Sol VTEC-E (SOHC)
EG2 B16A2 USDM 1996-1997 del Sol VTEC (DOHC)
EJ1 D16A JDM All 2-door
EJ3 n/a JDM All 2-door / 4WD
EJ6 D16Y7 CANADA All 2-door DX/Si
EJ6 D16Y7 CANADA 2000 2-door DX-G
EJ6 D16Y7 CANADA 1996-1998 3-door CX/CX-G
EJ6 D16Y7 CANADA 1999-2000 3-door CX/DX
EJ6 D16Y7 CANADA 2000 3-door SE
EJ6 D16Y7 CANADA All 4-door LX/EX
EJ6 D16Y7 USDM All 3-door CX/DX
EJ6 D16Y7 USDM All 4-door DX/LX
EJ6 D16Y7 USDM 1999 4-door DX-V
EJ7 D16Y5 USDM All 2-door HX (VTEC-E)
EJ8 D16Y8 CANADA All 2-door EX
EJ8 D16Y8 USDM All 2-door/4-door EX
EK2 D13B JDM All 3-door/4-door
EK3 D15B JDM All 3-door/4-door
EK4 B16A JDM All 3-door/4-door
EK5 D16A JDM All 4-door 4WD/LEV
EK8 D16A JDM All 4-door 4WD/LEV
EK9 B16B JDM All 3-door Type-R
EM1 B16A2 CANADA 1999-2000 2-door SiR
EM1 B16A2 USDM 1999-2000 2-door Si
7G (2001+)
EM2 1.7L USDM All 2-door DX/LX
ES1 1.7L USDM All 4-door DX/LX
??? 1.7L USDM All 2-door HX
EM2 D17A1 USDM All 2-door
ES2 D17A1 USDM All 4-door EX
EP3 K20A3 USDM 2002 3-door Si
??? K20C1 JDM All 3-door Type-R
you will need the shiftlinkage from the Del Sol VTEC model.
1999-2000 OBD2 "B"
1996-1998 OBD2 "A"
1992-1995 OBD1
1986-1991 Pre-OBD or OBD0
and jdm_loser is a tool
4G (1988-1991)
5G (1992-1995)
6G (1996-2000)
7G (2001+)
1999-2000 OBD2 "B"
1996-1998 OBD2 "A"
1992-1995 OBD1
also be sure that your NOT getting a cable tranny with that since your current setup is Hydro. You'll have to pay extra for a conversion kit to make hydro -> cable
also get odb1 since you'll get the right ECU/DIzzy/injectors/mostly the right mounts for the swap
Re: del sol swap (Cnote)
why i woudl want the OBD0 **** since it normally cost more than OBD1 stuff sell the OBD0 **** and put some money in ur pocket
dragooner00
14
10-24-2010 11:09 PM
