need info on installing a itr rear sway bar on ej1 coupe
I would like to install either a 22mm or the 23mm rear itr sway bar on my ej1 coupe. I currently have the stock EX front sway bar and I am also using the skunk2 lower tie bar. I'm wondering if the sway bar will alow me to still use my current tie bar?? I talked to a buddy of mine and he used the following:
- type r lca's
- 22mm way bar
- energy suspension d brackets
- gsr bracket that mounts to the frame
is this setup good? I'm wondering if it will tear the subframe in the logn run? also...is the beaks kit really needed?
WOuld u guys recommend getting the bsq kit instead of changing LCA's? please help.
info will be helpful. thanxs in advance!
Modified by 95-EJ1 at 1:38 PM 5/21/2004
- type r lca's
- 22mm way bar
Re: need info on installing a itr rear sway bar on ej1 coupe (95-EJ1)
use the bsq's kit or the beaks joint cause regardless of the lcas you stand the risk of subframe tears. not cute
dj theoretic
11
01-18-2009 11:49 AM
gakkuken
21
05-23-2003 02:29 PM
dgdarien
10
03-30-2003 01:09 PM
IntEGNYC
01-10-2003 10:38 AM
