Need some info about a b16a1 swap into 92-95 hatch
I have a b16a1 that I want to swap into a 92-95 hatch. What are the issues around obd? I know the engine is obd 0, are the cars from that series obd 1? The other thing I am wondering about are the motor mounts, will this engine bolt right in or will I need special motor mounts?
Any other info about his swap that would be "useful" that you want to pass along is much appreciated. As always thanks for the help.
Re: Need some info about a b16a1 swap into 92-95 hatch (LiL Jon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LiL Jon »</TD></TR><TR><TD CLASS="quote">Get some hasport bseries motor mounts and it drops right in </TD></TR></TABLE>
Yea, it will drop right in, and then just sit there since you won't be able to hook it up.
The easiest way would be to get a hydraulic tranny, a complete OBD I intake manifold with all sensors, and injectors, and a OBD I vtec B series distributor.
If not, you need a cable to hydaulic conversion kit, and a butt load of wiring. IMO, sell the 1st gen, and just spare yourself, and get the 2nd gen. Not to mention in emission controlled areas it's an illegal swap.
Re: Need some info about a b16a1 swap into 92-95 hatch (92b16vx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92b16vx »</TD></TR><TR><TD CLASS="quote">
If not, you need a cable to hydaulic conversion kit, and a butt load of wiring. IMO, sell the 1st gen, and just spare yourself, and get the 2nd gen. Not to mention in emission controlled areas it's an illegal swap.</TD></TR></TABLE>
I didnt realize it was so extensive. I thought I could get away with motor mounts and perhaps a wiring conversion.
Guess not....
Guess not....
Re: Need some info about a b16a1 swap into 92-95 hatch (giff74)
So is it nearly pointless to put a b16a1 into an eg or ej? Considering the amount of work it would require.
dem0nk1d
16
01-20-2007 06:55 PM
EGcivicBoy
17
01-16-2004 12:10 PM
