help needed with swap
Old 09-21-2004, 11:37 AM
hondsie's Avatar
Default help needed with swap
This is a relatively easy swap i'm told and i'm an apprentice mechanic so i'm getting used to doing basic R&I's. The car i'm swapping is a 93 civic with a D15b7 i'm replacing that with a D16Z6. Now I need someone who's done this swap to tell me what will fit what won't and what I need assuming i get the Z6 without distributor,intake,wiring(harness or ecu), and exhaust manifold.
hondsie is offline
Old 09-21-2004, 11:47 AM
ABK
ABK's Avatar
Default Re: help needed with swap (hondsie)
what will fit:
exhaust, tranny, wiring harness (few mods to make it run right 4 wire, and wire up the vtec), ecu will work but suggest replacing it ASAP, alternator and all the accesories transfer over.
There is bunch of other crap that I didn't mention.
What will not fit:
Distributor, IM, driver side engine mount from b7 (you will need to trasfer over the whole engnine mount assebly from b7 to make it work on z6, if you don't have the z6 one), spark plug wires
ABK is offline
Old 09-21-2004, 12:12 PM
I'm really 2slow
2fast4u831's Avatar
eveything should fit.
2fast4u831 is online now
Old 09-21-2004, 12:16 PM
hondsie's Avatar
i'm sorry but 4-wire o2? if so the car already has one and what is involved in wiring up v-tec?
hondsie is offline
Old 09-21-2004, 12:29 PM
I'm really 2slow
2fast4u831's Avatar
wire 3 wires and get the p28 or other vtec ecu and good to go. search for wiring vtec
95Hatch_209
10-22-2015 03:05 PM
s1ngleslam
10-30-2008 11:14 AM
jackhunt321
09-29-2006 10:06 AM
tolowhb
10
08-05-2003 07:21 PM
-[95cxhatch]-
07-22-2003 01:10 AM
Quick Reply: help needed with swap
  • Ask a Question
Question Title:
Description:
