HELP HELP HELP........00 si b16a2 into 98 hatchback..
Ok im getting really confused here. I bought a 99-00 Si motor (b16a2) which is an obd2 motor. But im now reading and it seams my car is an obd2a and the si motor is obd2b. I just want to know if this will still work for my car. These are my questions....
1. Can my dx wiring harness be wired for vtec and work with this motor? Or do i need a converstion harness or whatever?
2. What mounts and brackets do i need?
Re: HELP HELP HELP........00 si b16a2 into 98 hatchback.. (speedehatch)
1. yes. you need to get a conversion harness obd2a to 0bd2b to run the 99-00 si ecu.
2.u can use your stock mounts except the rear mount has to be a 99-00 si or you can get hasport mounts.
and yes you can wire your dx harness for vtec.. youll have to change the plug on the IAT and CKF.. add a knock sensor.. vtec soleniod.. vtec pressure switch.. and move wires up and down the harness..
Re: HELP HELP HELP........00 si b16a2 into 98 hatchback.. (Phatch99)
Ok can someone tell me if this will work....
My shop wires my dx wiring for vtec and i use a 98 GSR ecu, again on a 2000 b16a2 motor.
This would eliminate the need for the conversion harness and work right?
Come on someone please help..........these are my 2 options...
1. Shop rewires my dx harness and i use a obd2a to obd2b conversion and use 00 si ecu.
2. Shop rewires my dx harness and i use a 98 GSR ecu (Will that even work?)
Also what mounts and brackets do i need for this 00 motor to fit into my 98 civic?
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedehatch »</TD></TR><TR><TD CLASS="quote">My shop wires my dx wiring for vtec and i use a 98 GSR ecu, again on a 2000 b16a2 motor.</TD></TR></TABLE>
The P72 ECU isn't the proper ECU for a B16A. It will engage VTEC too early at 4400 RPM, thus causing a loss in power from 4400-5500 RPM.
Re: HELP HELP HELP........00 si b16a2 into 98 hatchback.. (Targa250R)
Ok wiring is through, ill use 99 si ecu with conversion harness
NOW WHAT ABOUT MOUNTS AND BRACKETS
i know there are some on my y7 that can remain, what do i need to get otherwise.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedehatch »</TD></TR><TR><TD CLASS="quote">Come on guys dont fail me now, just a list of the mounts/brackets i need. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Phatch99 »</TD></TR><TR><TD CLASS="quote">
2.u can use your stock mounts except the rear mount has to be a 99-00 si or you can get hasport mounts. </TD></TR></TABLE>
First reply to your thread!
Re: HELP HELP HELP........00 si b16a2 into 98 hatchback.. (Vero)
Well my shop told me different. They told me that i needed driver side mount and bracket, and the rear engine bracket( that L shaped one). Everyones telling me different. I need someone who has done this swap...
EKcivicEK
10-25-2009 09:00 AM
ordny6
04-19-2008 07:27 AM
wickedcrx
01-19-2003 06:36 PM
