d15b ?'s
Guest
Posts: n/a
d15b ?'s
Well I'll be picking up my D15bvtec engine this saturday so are there any little thing I need to know about before installing it? Like the o2 sensor with the one wire and four wire setup? I plan on using the the P08 ecu and since my hatch is a 92 hatch it's already ready wired for vtec so it's just as simple as plugging in the ecu and not moving any wires in the harness? I need this thing running by sunday and no headaches or curveballs along the way. What about the oil pressure sensor on the solenoid? If I use a P28 what do I do about the oil pressure sensor being that they don't come with them on there from what I've heard?
Re: d15b ?'s (egizzle6)
1. Look in through the oil cap and make sure the head is a nice grey aluminum color under the valve cover.
2. P08 ECU will run 1 wire o2. P28 will need a 4 wire.
3. I believe you will just need to run two wires from the underhood connector junction to the VTP and Spool Valve.
4. My D15B had the VTP sensor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egizzle6 »</TD></TR><TR><TD CLASS="quote">what the heck is the VTP and spool valve? This is the first time I've ever heard of them?</TD></TR></TABLE>
The proper terminology for the VTEC pressure switch and VTEC solenoid.
Chronicsinners
01-01-2005 07:23 PM
