What type of tranny fluid for B16A with LSD tranny?
cute little bastard
Sorry for this repetative question. I did a search but im a dummy so... What kind of tranny fluid do I use for my JDM B16A with LSD tranny? Name brand and weight please. THanks in advance
Re: What type of tranny fluid for B16A with LSD tranny? (SkoundrelUSA)
Religous argument around here.
Your primary choices are,
good 'ole Dino 10w30 (don't use synth)
Honda MTF
Your other Choices are,
Some other 70w80 Gear Oil (Redline, etc)
GM SynchroMesh with or without the "Friction Modified" label
I suggest one of the first two until you're comfortable with everything, then do a search on "GM Synchromesh" and read the many myriad arguments on the subject.
Honda MTF
cute little bastard
Re: What type of tranny fluid for B16A with LSD tranny? (project_mercy)
Well right now I'm running 80w90 I believe. Should I drain it out? Remember this is for LSD TRANNY
80w90 should be fine that's closer to Redline MT-90.
You're running an OEM Helical LSD. It doesn't affect your oil. Clutch LSDs sometimes require an additive.
This user can set his title.
Re: What type of tranny fluid for B16A with LSD tranny? (pane93civhb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pane93civhb »</TD></TR><TR><TD CLASS="quote">motor oil for all honda tranny's u dont need didnt tranny fluid. </TD></TR></TABLE>
What the ?!?! Motor oil for all honda tranny's?! ummm... NO...
I have a stock R tranny w/ LSD and I use Honda MTF only.
Mr. Badwrench
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkoundrelUSA »</TD></TR><TR><TD CLASS="quote">Well right now I'm running 80w90 I believe. Should I drain it out? Remember this is for LSD TRANNY</TD></TR></TABLE>
HUH? how hard is it to get into gear on cold days? i made the gear oil mistake once and couldnt get into first when it was cold.
HONDA MTF ONLY!
HONDA MTF ONLY!
Re: What type of tranny fluid for B16A with LSD tranny? (boostedcivicsir)
honda MTF. is it becuz its a lsd tranny or just becuz its better can someone clarify for me.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir »</TD></TR><TR><TD CLASS="quote">
HONDA MTF ONLY!</TD></TR></TABLE>
hahaha
Guess what Honda MTF is?
The lot of you, go read this thread.
https://honda-tech.com/zerothread?id=641177&page=1
hahaha
in the honda serivce manual, it says you can use 10w-30 in place of honda MTF if its not available. i dont know if it applies to LSD tho....
:edit: i just checked the helms for teg's. its says to use 10w30 or 10w40. it doesnt even say use honda MTF. wierd.
Modified by dantastic at 11:39 PM 9/23/2004
Correct me if im wrong, but its a LSD tranny, I have told by my mechanic that u need to use something thick.
I use Motul Motylgear 75W80 Technosynthese
Re: (sinister6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sinister6 »</TD></TR><TR><TD CLASS="quote">Correct me if im wrong, but its a LSD tranny, I have told by my mechanic that u need to use something thick.
I use Motul Motylgear 75W80 Technosynthese </TD></TR></TABLE>
honda mtf is a 75w80.
If you have a Clutch type LSD like the one's that came with some JDM B16's you should only use CUSCO LSD Fluid or KAAZ LSD Fluid. If you have a Helical LSD then you should be fine with Honda MTF.
Re: What type of tranny fluid for B16A with LSD tranny? (AdamQ3B85)
Torco makes good stuff too.. as well as a LSD additive for the tranny fluid. torco knows how to make power trust them.
http://www.torcoracingoils.com...ket=8
spinney
09-24-2005 06:14 AM
crx(gator)
12-10-2001 09:41 AM
