97 Civic timing light help ?
Old 09-21-2004, 12:40 PM
alotawatts's Avatar
Default 97 Civic timing light help ?
I want to check my 97 Civic EX D16Y8 with my timing light. I know what RPM to use but I do not know what else is necessary for idling as for as electronic service connector jumping , knock sensor bypassing or other stuff like that. My service manual explains connecting Official Honda Service meter ABCDE to the XYZ.
I'm looking for a simple old-school method with my light if that is possible ?
Thx
alotawatts is offline
Old 09-21-2004, 01:03 PM
Default Re: 97 Civic timing light help ? (alotawatts)
let car warm up (fan should cycle twice)
Jumper the service connector (blue connector hanging under the dash above the ECU). paperclip or wire or something to short the 2 contacts
hook up timing light to 1st cylinder
Shoot at "red" line on the main pully, lining it up with the long black line on your lower timing belt covor
If not correct, loosen distributor and twist till it is correct.
Tighten bolts when you're done and remove service connector.
project_mercy is offline
Old 09-21-2004, 01:15 PM
alotawatts's Avatar
Default Re: 97 Civic timing light help ? (project_mercy)
Thanks project-mercy
So the service connector only has two contact points total ?
Old 09-21-2004, 02:18 PM
Luserkid's Avatar
huh? Why jump the jumper?
Luserkid is offline
Old 09-21-2004, 03:27 PM
Default Re: 97 Civic timing light help ? (Luserkid)
Go hook up a timing light without the jumper and watch it
You'll notice that the distributor cap is astoundingly wide. Reasoning, it gives your ECM/ICM the ability to 'tweak' your timing, and it'll do it through a series of high and low idle periods, basically making your car impossible to time accuratly.
Jumping the service connector removes the ECM's ignition tweaks.
pimpwagon
12-07-2010 05:55 PM
royalfelix
02-20-2008 06:23 PM
TODA GS_R
09-25-2005 01:04 PM
extrmeboost
02-08-2003 07:13 AM
94civicx
03-20-2002 10:43 PM
Quick Reply: 97 Civic timing light help ?
  • Ask a Question
Question Title:
Description:
