d16 w/nitrous 1/4 mile time
Old 09-20-2004, 08:45 PM
street sleeper's Avatar
Default d16 w/nitrous 1/4 mile time
I have a 98 EX coupe, full interior
my mods are:
intake
header
exhaust
12lb flywheel
exedy clutch
[email protected] 50psi
no p/s
no a/c
wet ZEX 75 shot
ZEX plugs
timing retarded 6 degrees
20-8-14 m/t slicks
cant think of anything else
my best time:
r/t .509
60' 2.084
330 5.853
1/8 9.002
mph 77.46
1000 11.754
1/4 14.092
mph 96.51
this was my best run of the day. I realy wanted a 13.9, and 2.08 was the best 60' I could pull, so does somebody have some sugestions of a quick mod that could take that .092 off, any sugestions would be appreciated.
thanks
street sleeper is offline
Old 09-20-2004, 08:56 PM
All Motor Mentor
00Red_SiR's Avatar
Default Re: d16 w/nitrous 1/4 mile time (street sleeper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by street sleeper &raquo;</TD></TR><TR><TD CLASS="quote">
thanks </TD></TR></TABLE>
You're running to much timing retard at -6, I would reduce that to at least -3 or -4 degrees retarded especially (but not necessarily) if you're running premium fuel with octane booster. Also your fuel pressure is set a little high at 50, I wouldn't set it any higher than 45psi MAX. Those simple changes should get you into the high 13's.
00Red_SiR is offline
Old 09-20-2004, 09:00 PM
yeah I thought about those, but ive never been much of a gambler, and have never dyno tuned, so I kinda wanted to leave in conservative,maybe il get it to the dyno, and se if they can tune it properly. thanks for the reply.
Old 09-20-2004, 09:05 PM
All Motor Mentor
00Red_SiR's Avatar
Default Re: (street sleeper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by street sleeper &raquo;</TD></TR><TR><TD CLASS="quote">yeah I thought about those, but ive never been much of a gambler, and have never dyno tuned, so I kinda wanted to leave in conservative,maybe il get it to the dyno, and se if they can tune it properly. thanks for the reply.</TD></TR></TABLE>
Yes I would recomend you go to get it tuned at a dyno because you could probably still trim your fuel and timing settings even more than I suggested. To say that you were running conservative is an understatement!...lol My advice that I gave you was based off of my own tuning experiences, but I still left a little safety margin in there for ya Good luck and great times you got there!
99skunkedSi's Avatar
that is a damn good time i would be proud of that if i were you! altough a 13 sec. pass would be even nicer. g/l
99skunkedSi is offline
Old 09-20-2004, 09:09 PM
yeah im happy with the car, but its kinda like bragging rights to say your in the 13's
Old 09-20-2004, 09:11 PM
true, hit the dyno and tune it and i'll bet you'll see 13's
Old 09-20-2004, 09:16 PM
I might have to do that, do any of you guys recomend any mods specificaly? plus I remembered I have a walbro 255lph fuel pump too.
Old 09-20-2004, 09:24 PM
All Motor Mentor
00Red_SiR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by street sleeper &raquo;</TD></TR><TR><TD CLASS="quote">I might have to do that, do any of you guys recomend any mods specificaly? plus I remembered I have a walbro 255lph fuel pump too.</TD></TR></TABLE>
You certainly don't need any mods to get you into the 13's and unless you plan on going boost at some point I'd sell that fuel pump as it's overkill for your car. If you really want more mods you won't have a problem finding them since you drive a civic but there aren't anything specific I'd tell you to get at the moment. Just add what you want when you want it and you'll be fine.
Old 09-20-2004, 09:28 PM
boostincoupe's Avatar
Location: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by street sleeper &raquo;</TD></TR><TR><TD CLASS="quote">I have a 98 EX coupe, full interior
my mods are:
intake
header
exhaust
12lb flywheel
exedy clutch
no p/s
no a/c
wet ZEX 75 shot
ZEX plugs
20-8-14 m/t slicks
my best time:
r/t .509
60' 2.084
330 5.853
1/8 9.002
mph 77.46
1000 11.754
1/4 14.092
mph 96.51
Atta boy Cam...you're faster than me for cheaper. Damnit.
boostincoupe is offline
Old 09-20-2004, 09:29 PM
actualy, the car used to be turbocharged(didn't work out) so back then I thought I neded the big pump. I think im gona take your advise, and head to the dyno, and tune.
thanks
Old 09-20-2004, 09:30 PM
you should have come out there sunday, it was a nice day.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by street sleeper &raquo;</TD></TR><TR><TD CLASS="quote">you should have come out there sunday, it was a nice day.</TD></TR></TABLE>
Hook me up with an axle.
Old 09-20-2004, 09:32 PM
I can get one for around 35-40$
Old 09-20-2004, 10:20 PM
Try the dyno run and that should get you there. If not, get a new set of pulleys if youd don't already have them. It should add around 10 hp and 8lbs of tq. That'll get you in there.
94HatchbackSI is offline
Old 09-20-2004, 10:25 PM
MassScene's Avatar
Im really impressed! good driving!
MassScene is offline
Old 09-20-2004, 11:19 PM
Timmay's Avatar
Default Re: d16 w/nitrous 1/4 mile time (MassScene)
i would say back the timing to -2 deg.
get rid of the zex plugs , maybe a ngk bkr73 gapped about .30
make sure to run premium
back the FP to about 42 line off
Timmay is offline
Old 09-21-2004, 12:05 AM
Default Re: d16 w/nitrous 1/4 mile time (Timmay)
If you work on your 60 Ft. that should get you there as well theres no reason you shouldn't be pulling low 1.90s with slicks atleast.
MAD SOHC is offline
Old 09-21-2004, 06:03 AM
thanks for the replys, im looking into a few more things, possibly a cam.
Old 09-21-2004, 06:36 AM
EK_vzla's Avatar
talk to mista bone
EK_vzla is offline
Old 09-21-2004, 06:39 AM
if you cant get to the dyno soon try taking some off the timeing maybe around -4 degs but thats just my opinon
opkjoblacsh is offline
Old 09-21-2004, 07:05 AM
Phatch99's Avatar
just gut out your back and u should hit 13's
Phatch99 is offline
Old 09-21-2004, 07:06 AM
you have exaclty the setup im looking to do wuth my d16y8 you lucky bastard just kidding but its weird that i set a 14.1 1/4 mile goal for myself with the same car , my current 1/4 time is 16.9 2.506 60ft 10.8 1/8 81.47mph cincinatti is not near sea level! just thought id share that im completly jealous. i set my goal at 14.1 to be able to beat a sti, although thwe last sti i ranb against was running 2.1 60ft 14.7 93.39mph
CRXstress is offline
Old 09-21-2004, 07:09 AM
Old 09-21-2004, 07:10 AM
Default Re: d16 w/nitrous 1/4 mile time (Mrwool983455)
oops i did it twice sorry, does anyone else notice that you can only do one search per online session whats up with that?
supragrl93
12-29-2007 12:06 PM
scansel912
Honda Civic (2001 - 2005)
05-08-2006 05:25 PM
FormulaGSR
10-08-2004 10:28 PM
Rah Rah
05-16-2002 04:10 AM
Rah Rah
05-13-2002 10:17 AM
Quick Reply: d16 w/nitrous 1/4 mile time
  • Ask a Question
Question Title:
Description:
