High beam wont work...
i have a civic and need help
my 94 civic hb has only one bulb in the headlight and for some reason only low beams work and one high beam does n e 1 know why
your headlights have 2 fillaments, one for your brights, one for you low beams. one of them is burnt out. try replacing it, if it does not work it looks like you have a wiring issue
Re: (Gman8941)
pull the questionable bulb out first, if one of the springs are broken, or there is a piece freely moving in the bulb, it just needs replacing, if not, check your wiring...
Re: (sprayedcrx)
Swap headlight bulbs. If the working highbeam follows the bulb, then replace the bulb. If not, follow wires.
Or maybe you should top off your headlight fluid
Darth ModerVader
Re: (sprayedcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sprayedcrx »</TD></TR><TR><TD CLASS="quote">ill check the wiring </TD></TR></TABLE>
I think the bulb is the more likely culprit, and much easier to rule-out than a wiring problem. Confirming that the bulb is good before checking the wiring is more logical in my opinion.
JudyNetel
10-09-2017 03:20 AM
accord ex
03-13-2003 05:55 PM
