axle trouble, need help.
I just installed 2 new stage 2 axles on my K-swap. after i finished up i went to test drive it. It drove fine for approx...100 feet. and then car just stopped going and the engine would rev in place. sounds like the axle is spinning free.
We torqued everything down...but hasport gave us 32MM axle nuts with the axles, but on the swap i had 36mm axle nuts. Does that have anything to do with it? because the axle didnt come all the way through the axle nut, maybe just a little more than half way.
Re: axle trouble, need help. (JUN EK9)
Did you put the pin back in the axle??? My friend forgot to do that and went to burn out and axle snapped:'( If you forgot to put that pin in that could be the prob. If not good luck.
Re: axle trouble, need help. (h34dm4n)
Derek, You have JDM CTR 5 lug hubs... Those have a 36 mm outer (Accord) hub you would need whoever builds the axles for Hasport to make you them with a accord outer. If you have any Issues with them Let me know My axle guy make ours for the K 125.00 per side all new parts inside and the have withstanded 7,000 rpm dumps on 24" slicks....
swarley
Transmission & Drivetrain
01-28-2011 06:56 AM
