Window weld mtr mount questions please help
I have read other posts about doing window weld motor mounts but they still don't really answer my questions:
Who has done it and how is your experience with it?
Did you or should you cut/burn the rubber out and use only window weld?
How long did it take to dry and what brand did you use?
any help is appreciated thanks!!
Re: Window weld mtr mount questions please help (_BEN_)
Yeah thats what hes talking about. Do not remove the factory stuff that is in there just clean it with some brakeclean and maybe scuff it up with a file, thats how i did mine.
The brand that you want to use is 3M...There is a few different grades, I cant remember the one that I used but the **** hardened to some where near concrete and the core of the great planet Megatron..
I personally would love to trade them out for something softer. I must be getting to old to like the rattle trap that my car has turned into.
Location: Just Drank A 5th of VODKA Dare me to drive, Ca, u.s.
Re: Window weld mtr mount questions please help (SoloSol)
it will make a difference...be ready for bit more vibration
Darth ModerVader
Re: Window weld mtr mount questions please help (96MidoriHatch)
With the prices of actual after-market inserts being as low as they are, I would suggest simply buying a set and saving yourself the effort and any potential problems.
Re: Window weld mtr mount questions please help (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _BEN_ »</TD></TR><TR><TD CLASS="quote">Whats window weld?
Are you talking about filling up your engine moints to make them stiffer? </TD></TR></TABLE>
yes making them stiffer as explained here http://importnut.net/motormount.htm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan »</TD></TR><TR><TD CLASS="quote">With the prices of actual after-market inserts being as low as they are, I would suggest simply buying a set and saving yourself the effort and any potential problems. </TD></TR></TABLE>
your probably right but i just wanna know
i think im just gonna do it if any are worn at all then if i don't like it i would be getting new ones anyway
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96MidoriHatch »</TD></TR><TR><TD CLASS="quote">i think im just gonna do it if any are worn at all then if i don't like it i would be getting new ones anyway</TD></TR></TABLE>
Just keep in mind that after-market inserts are designed to fit into your existing mounts, so you won't be able to use them once you do the DIY method.
mingchi69
24
05-24-2004 12:50 AM
