Alignement for a drop suspension
1 Post
I am wondering do I need to have a camber kit to be able to have an alignement done. Right now my car is seating on neuspeed race and toxicos. So wondering what I should do????? Need help fast !!!!!!!!!!!!
Dave
Dave
Re: Alignement for a drop suspension (handa)
you pretty much only need an alignment if you like having a car that goes perfectly straight. and you don't want your tires wear out on the sides fast.
so if you want both of those get an alignment.
Re: Alignement for a drop suspension (93SiVtec677)
Agreed. I lowered my car 2 inches, got it aligned, the next day it was runnin me off the right side of the road It's back to stock height now and I still have problems w/ it..could be due to the fact I let a complete idiot slave over my suspension.
Re: Alignement for a drop suspension (gftgrill)
an alignment does NOT fix the CAMBER. All that alignment will do is fix your TOE settings, generally on a street car you want the toe settings to be as close to 0 (zero) as possible.
A camber kit on the otherhand, will NOT FIX the TOE settings. All it does is fix CAMBER. there's a huge difference between the two. All Camber does is adjust the angle at which the wheels sit perpendicularly to the ground.
PM me if you have questions.
taimysho0
15
10-11-2023 09:49 PM
R_Machine
09-23-2003 12:27 PM
